Largest or biggest CCA battery Made
Odyssey pc 2250. 1225 cold cranking amps
Hmm i should of reworded that to most AH hahah...
Sorry, im looking for a single battery to hold up on 10-20k daily until i buy all my alternators.
Ill just have the single singer 275 amp on it
I
Hmm i should of reworded that to most AH hahah...Sorry, im looking for a single battery to hold up on 10-20k daily until i buy all my alternators.
This is one of the best and biggest you'll get by less you go with a computer battery. Seen one that had 250 ah on it
The Batcap is a multicellular battery so if you are considering competing. It will put you in a higher class. But so will all the other batts to XS power also make a lithium battery as well
Juicebox Lithium
One of them new lithiums $1500 though or batcap 8400?
pretty sure he said somewhere he'll make these in 1kwh or higher if you pay.
0.5KWH (500WH) Lithium Iron Phosphate Unit | JuiceBox Battery
1500$ batteries each ahha got damnn! Ill have to do more research on them as i dont want to go lithium until i know more. Ive tested one lithium and had issues.
I might end up getting 2-3 batcap 8400's if it comes down to it over time.
edit: i see those batteries are for burp. Im looking to do daily drives no competing unless i meter a couple of times.
Yea thats what i saw that lithiums actually work best for burps, i was planning on getting the 20ah one which is $799 but then i did research and for someone who will not burp and for daily music no metering the XS xp3000 is probably best bet and they arent too expensive $320 120ah i think i might just get 2 of those or d3100s only thing stopping me is the **** weight which wa smy reason for looking into lithiums they weight like 30lbs or something
The odyssey batts are better for daily and demos that's why I run them. I've tested them against kinetik stinger Batcap XS power and even Deka and c&d. The odyssey hands down
DO you happen to sell the said odyssey bat you mentioned?
Not purchasing today, but plan to buy some on the way. At the cost of that odyssey battery which runs 500+ i could get 3.
los33
Car Audio G
los33
Houston, TX
big scott
