L7 or SDC2.5?
they both have the same sized 2 3/8 coil. you dont have the power for the L7's. with the right power the kickers will get louder no doubt. when have you seen a pair of aq 2.5 break the mid 50s.
I've built a few 2 15" SDC set ups for guys powered by a 1200D and they were quite impressive for budget set ups. Sounded good and pounded the lows. 8.5cubes @ 38hz for each set up. Very solid sub for the $$$.
x2 on the Q wanting more power then 600watts...
I had a 12" L7 off a ZX750.1 and it got loud but I think my SDCs sound a lot better while still getting loud. I ran a single 15" SDC off the ZX750.1 for a while before picking up 2 and the SAE-1200D.
not to dump on the thread but do you have pics of your setup? im about to put 2 15's in the back of a crown vic and i just happened to see your sig
Well since I just rounded up more cash I have enough to get the HDC's. Would the AQ2200D match these subs? Also I have a question about wiring. I have a book called the Car Audio Cookbook and what I read was that on a mono block amp there is no way to wire dual voice coil 4 ohm woofers to 4 ohms. It said that you can only do that with a multi channel amp. Is this true or can you wire a dual voice coil 4 ohm woofer to 4 ohms?
No you can not wire a D4 coil to 4ohms no matter what amp you have. If you had a 2 channel amp you could power each coil on each channel of the amp. You would need 2 D4s to wire to 4ohm. Or a single D2.
And also if cash was an issue i would say get the Kicker CVX's. A pair of 15s of those in like say 8 cubes tuned to 35 would just get nasty with a AQ2200 on them. And as long as the port area isnt above a 100^2inches i would be willing to bet that you would say they are clean as hell also. The cvx is one of my all time favorite budget subs without a doubt. I actually ran a AQ2200 on a cvx 12 for awhile. Had it in a SQ box that was 2cubes tuned at 34hz did a 144.6 with it on the Tl. I will admit it was a bit much power for it only cus the suspension didn't like it but thats it.
Jimmaaay
Greek Man
Jimmaaay
Concord, CA
Jimmaaay
