L7 15in 2 ohm+1.7cu ft sealed+kac-9105D (1800/900RMS) Can and should I add a L5 15 ?
Yeah man hook that L7 n l5 up two diff subs should slam! Careful might break your back window //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
You box. S u c k s. L7 are best in ported and due to added cone area need larger boxes. You need like 6 cu with a lot of port tune between 32-38hz. The higher the tune the louder but less lows.
Sell the L5, get a better box for the L7. As big as you can fit. It'll make a world of a difference, more then cramming another sub in there. You don't have enough power to run both, and they do not match. How ever the L7 and the one amp match well and getting or better yet building a bigger box is cheap and will yield much greater results.
Wire it to 1 ohm , not 4. Make sure you have decent wiring and a half decent battery too to run 800-1000w rms.
Get a smaller sub single 10 in a well built ported box. Shouldn't take up much more space. If you like sealed get a sub better suited for sealed boxes.
OP a 15" L7, L5 or L3 isn't going to work in that small of a sealed box. You'll get no output out of it. You'd need at least 5-6 cubes to get a decent response. And I agree with dbjunior. Get a good 10" like maybe an American Bass xfl and throw the 900 watts at that in a good ported 1.5-1.7 cube enclosure if that's all the space you have to work with.
Rpost777
Rpost777
Louisiana
DoesDad
