kx350.4 and cd8053
knotslck
i just ordered both of these and i saw this on a website.
* Power (WATTS/CHANNEL), 2 Ohm Stereo: 90 x 4
* Power (WATTS/CHANNEL), 4 Ohm Bridged Mono: 175 x 2
* Fan Cooling
* Frequency Response: 20Hz-20kHz; +0, -1dB
* Input Sensitivity: High Level 340mV-10V, Low Level 170mV-5V
* Active Crossover: 12dB/Octave, variable 50Hz-200Hz, selectable high, low, or all pass
* KICKBass Boost: Variable to +18dB, (KX200.4 variable to +18dB) centered at 40Hz
will i be able to run my 8 volt preout with this amp? it says only 5v on the low. is low the rca and high the speaker wire inputs? how can i wire this and make it work and will this amp take the 8v preout without clipping?
thanks.
knotslck
knotslck
who cares?
knotslck
