Sold Knu distros, RCA's and misc
SPY
1. Product:
Knu KonFUSED 2 Way Digital Distribution System
2. Specs:
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-22D has Two input ports, which by changing the Kompression Fitting, can accept 4 Gauge or 1/0 Gauge Cable. The output side can be adjusted to accept 4 Gauge or 8 Gauge cables. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-22D can maintain loads up to 150A per circuit.
The Digital Display is illuminated by Blue LED's and requires a ground wire to be connected to the base mounting screw on the output side of the block
3. Description/Condition:
Used but in good condition, I have some fuses I will include as well as some other compression fittings. PM me with what you want for input/output fittings and fuses and I'll see if I have it. Pics show the fuses and fittings I have but they do not all come with this sale, they will be split up between this and my other distro block sales.
4. Price: :
$18 + shipping.
5. Pictures:
1. Product:
Knu KonFUSED 3 Way Distribution System
2. Specs:
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KNF-23 has two input ports, which by changing the Kompression Fittings, can accept 4 Gauge or 1/0 Gauge Cable . The two of the three ouputs can be adjusted to accept 4 Gauge or 8 Gauge cables while the last output can be configured for FUSED 1/0 or 4 gauge output . The KNF-23 has 18 Unique Konfiguratons. Please see our reference chart link below to see what fittings are included with this model. Using the Mini-ANL Style Fuse, the KNF-23 can maintain loads up to 150A per circuit.
4. Price: :
$15 + shipping.
5. Pictures:
1. Product:
Knu KonFUSED Ground Distribution System
2. Specs:
The KonFUSED Distribution System is tailored by the installer to fit ANY installation requirement. With interchangeable Kompression Fittings anything is possible. The KND-23 has two "large" ports for 1/0 or 4 gauge cables and three "small" ports for use with 4 gauge or 8 gauge. (ground blocks are "common" points, so there is no technical "in" or "out") The KNF-23 has 12 Unique Konfiguratons. Please see our reference chart link below to see what fittings are included with this model. Included with the KND-23 are 6 Kompression Fittings to allow the end user to customize the block to fit their application. The KND-23 is finished in black chrome and includes the smoke acrylic cover.
Used but in good condition, I have some other compression fittings to change the setup. PM me with what you want for input/output fittings and I'll see if I have it. Pics show the fittings I have but they do not all come with this sale, they will be split up between this and my other distro block sales.
4. Price: :
$12 + shipping
5. Pictures:
1. Product:
4g set screw type ring terminals. I believe thay are Stinger HPM but I'm not positive.
2. Specs:
Accepts up to 4g wire
4. Price: :
$5 + shipping
5. Pictures:
SPY
SPY
NY
SPY
