kit?
I had to trim off a good amount of strands from my 0/1 gauge wire to get my kicker direct connects to accept the wire. I just used a wire cutters to snip off a couple chunks around the outside of the wire.
I use the part if the wire strippers that has the multiple openings for stripping different gauges and lightly squeeze around the wire it does a good job of thinning the wire down without it looking hacked up because it cuts the strands in different places instead of hacking out thick chunks of wire.
Well I think doing that wasn't allowing enough power to my amp because it went into protection mode and shut off, only about 1/4 of the power and ground wires were in the terminals. Think I'll just get an adapter and some 4 gauge wire
mr.gaf
mr.gaf
Shreveport, LA
mr.gaf
