additional info
KICKER RS-Series Component Systems Blending perfectly to create stunning musical accuracy, KICKER RS-Series Component Systems reveal midrange and high frequencies like no other. Its impeccable mids and the truest tweets as clean and pure as your ears will ever experience! RS uses tough midrange drivers with high power handling and a center plug where tweeters can mount to create unbelievable coaxials. And the tweeters are some of the best available, composed of a DuPont Tetoron dome and other cutting-edge materials that give your highs incredible volume. It all works flawlessly with the help of a more-than-capable passive crossover network. Youll find two sizes of RS Systems - one with 6.5-inch mids and one containing 5.25-inch mids with 6 x 8 adapter plates if your ride requires them
6-1/2" 2-Way Component System
RMS Power Handling: 100 watts
Peak Power Handling 200 watts
1" dome tweeter with neodymium magnet
Enhanced BAM (Basket and Motor) Assembly
Optimized Composite Rubber Surround Radius
Coaxial tweeter mounting option
Passive Crossover Network
Spring-Loaded Nickel Plated Terminals
Water resistant, marine mounting hardware included
