kicker ssmb6 as part of components
nebur8
Hey noob here. I have an older set of reference series infinities one of my mids blew, and was wondering if i can replace them with a set of ssmb6's. If i can't how are the kicker ks6.2? I'm sticking with kicker b/c i get some pretty great prices on them
Thanks for the help.
Usually the crossover is tailored to the speakers it comes with... if you use another driver, the response might not be flat.
Why not call Infinity and see if you can order a replacement mid. Otherwise, I would just buy a new component set of your choice.
I contacted infinity and they no longer make the replacement mids. so the ssmb6 won't work. well what I was looking at the ks series of comps any opinions?
I have a pair of Kicker KS65 coax's, and they sound great for the price. Since the components let you choose a location for the tweet, I'm sure you could arrange them to make them sound even better.
Swick
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
574
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
nebur8
nebur8
Miami, FL
prodgod
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
