Kicker Kx 800.2, Holla Back!!!
  • 3
RONDUKES52
QUICK QUESTION, IS THE KICKER KX 800.2 ENOUGH TO POWER 2 X KICKER SOLO BARIC 7 10" SUBS? JUST WONDERING BECAUSE I DON'T THINK I'M GETTING THE MOST OUT OF MY SUBS WITH THIS AMP BECAUSE OF MY SETTINGS. I'M NOT SURE HOW MUCH GAIN, BASS BOOST & CROSSOVER CONTROL I SHOULD USE. MY HEAD UNIT IS THE SONY XPLOD M620. SOMEBODY HELP ME!!!! DON'T GET ME WRONG, THE SYSTEM SOUNDS NICE, BUT I THINK I COULD GET A LITTLE MORE BASS OUT OF THEM. I HAVE MY SUBS IN A SEALED BOX.
Those subs can take a pounding. I would recommend an amp that can push at least 500w RMS. Then you will hear a hell of a difference. Also, add a cap and that will help too
Ive got 2 10" L7's each powerd bye a JL 500/1 and these subs pound like hell.
You should look for an amp that is at least 1000 watts RMS, if your gonna power both w/1 amp at least 500 RMS if your gonna power each off a seperate amp.
if u have any other questions post it, and ill get right on it.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
722
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
RONDUKES52
RONDUKES52
BRONX, NY
fu-man-chu
1aespinoza
    May 23, 2024
Doxquzme
    May 22, 2024
