Kick Panels... :sigh:
Why not just make a couple of brackets and mount the tweeters over top of the mids. It works quite well. And you wouldn't have to sacrifice your imaging. Get what I'm saying ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah...I get it...
I really don't mind imaging...it'll still sound decent...
Just something better than 4x6's....4x6's I TELL YA!!!
- Steve
After seeing the pics with a midbas driver in their, I don't think that would be a problem. I thought the dept would be an issue...but lookin at those pics, it looks ok.
Just make some tear dropped baffles and point them up. ( Just like you said Ramos //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ) I don't have any experience with your car so I'm not sure if the 6.5" would fit under your e-brake.
Where did you relocate the e-brake on your install...Ramos?
Is it really such a pain that you would compromise for 5.5" ?
Ohhhh I can't imagine how much of a pain in the ass that would be...I bet installing a C-notch and having to box rear frame rails would be easier:D
Ah well, we'll see...
- Steve
Man you don't even won't to know //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I ended up moving it right under the edge of the drivers seat. Had to turn it into a pull up handle instead of a pedal. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Steve....i have the same problem on my Intrepid with the brake. I may have found a solution //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif .....i will know early next week if i can make it happen...gotta call a few peeps.....i'll pass the info if everything works out....
man steve why you gotta be hatin:(. like i said earlier though i'll get pics and i'm gonna end up getting 6.5" midbass alongside sealing off the kicks. by the time i'm done i'm hoping they won't look pre-fab hehe:D.
adam
Yeah Adam, hopefully pics will give me a little bit more hope lol.
Ah-ha...
http://www.sounddomain.com/shop/item.pl?sku=QLCQLK1003B01&vq_id=none
- Steve
The q-forms aren't all that bad actually with a little work. Take some bondo hair and stiffen them up on the inside. Then dye the outside with vinyl dye to match your interior. Or you can cover them in matching carpet. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
$130 isn't too bad, either...would save me a lot of hassle and swearing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
- Steve
- Steve
A can of dye and a can of bondo glass will probably run about $20. Of course up there in the great white north I don't really know //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Had to throw a crack about Canada in there, eh? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Bondo is cheap..is that stuff called "UltraGlass"?
- Steve
- Steve
I couldn't help myself //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I believe that's the same thing. There are a bunch of different brands. I personally use marglass. As long as it has the chopped glass strands in it. It will work fine. I just wouldn't use plain body filler. It will crack by iteslf. Don't want your kicks to have a rattle inside the first time you accidentaly hit them with your foot. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
- Steve
see even ramos says they aren't too bad lol. yeah imma seal the backs of mine up with some glass work as soon as i have the time to do it. 130 isn't bad but when i worked at best buy i got em for 90 after shipping.
adam
ss3079
Eh Dere Hi Dere Ho-ser
ss3079
Up North
bumpin_blazer
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
