Kenwood X810D $140 (stats are comparable to X9106D @ $299)
400 watts RMS x 1 at 4 ohms
800 watts RMS x 1 at 2 ohms
1,000 watts RMS x 1 at 1 ohm
Bass Management System
50-200 Hz low-pass crossover, 24 dB/octave
infrasonic filter (15 or 25 Hz selectable, 24 dB/octave)
12 dB bass boost variable from 40-100 Hz (expandable to 6/12/18 dB)
phase inverter (0-180 degrees)
preamp outputs
speaker short, low battery, thermal overload, and DC protection
variable color indicator
gold-plated terminals
detachable terminal covers
17-5/8"W (14-5/8" without terminal covers) x 2-5/16"H x 12-3/8"D
Kenwood KAC-8404 $80 (predecessor to the KAC-8406 @ $229)
4-channel car amplifier
50 watts RMS x 4 at 4 ohms (75 watts x 4 at 2 ohms)
180 watts RMS x 2 bridged output at 4 ohms (4 ohm stable in bridged mode)
2-, 3-, and 4-channel operation
CEA-2006 compliant
high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
variable bass boost (0-18 dB at 40 Hz)
cooling fan
MOSFET power supply
speaker-level inputs with signal sensing turn-on
preamp-level inputs
fuse rating: 40A x 1
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
11-1/16"W x 2-5/16"H x 9-7/8"D
Rockford Fosgate Prime R150-2 $40 (new is $120)
2-channel car amplifier
50 watts RMS x 2 at 4 ohms (75 watts RMS x 2 at 2 ohms)
150 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
CEA-2006 compliant
high-pass filter (80 Hz, 12 dB/octave)
variable low-pass filter (50-250 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 45 Hz)
Class-AB amplifier design
MOSFET power and output stages
frequency response: 20-20K Hz
preamp inputs and outputs
10-gauge power and ground leads recommended — wiring and hardware not included with amplifier
fuse rating: 20A x 1
7-3/4"W x 2-1/2"H x 12-1/8"D
All items used, work well with no faults, stored in climate controlled conditions for over a year, maybe two.
$140, $80 and $40 respectively.
Actual shipping costs are the buyers responsibility. Will shop around for best prices and pack very well. Will include as many accessories, etc as I can find (RCA's, etc) but no promises.
preamp outputs
CEA-2006 compliant
cooling fan
MOSFET power supply
preamp-level inputs
CEA-2006 compliant
