KENWOOD KAC-9104D hooked up to Alpines
CantGetEnufBASS
ME > YOU
I am about to buy 2 ALPINE SWR-1042D 10" I think im gonna go with the 4-ohm because the 2-ohm cost the same. I plan on running them off a 1800 watt KENWOOD KAC-9104D (KAC9104D) Class-D MONO, that pushes RMS Power Output @ 4 Ohms : 500 Watts x 1-Channel...RMS Power Output @ 2 Ohms : 900 Watts x 1 Channel . do you think this amp will sufficently power my subs? IF NOT PLEASE RECOMEND A BETTER SUB THAT IS NOT EXTREMLY EXPENSIVE I ONLY HAVE $220 FOR A AMP
why would you want to power them at 4 ohms?
And id get a amp for each sub and wire them at 2 ohms each.
Since you only want to spend 220, id look at getting a different amp... Aq1200d's are only 249 shipped and will do 1200@1
I've seen kac-9102d's go for 60 bucks on ebay... same thing as yours except 850w instead of 900
CantGetEnufBASS
ME > YOU
CantGetEnufBASS
LA, CA - Austin, TX
jdawg90
