the amp is only a few months old it was in a show car that i sold it was only powering 2 10s at a 1/3 of the gain make an offer also up for trades
180.00obo
specs
The all new line-up of Kenwood amplifiers is quite impressive. These amps are a huge improvement from last years models. These amps carry more RMS power, and better fine-tuned sound, not too mention the new look of these amps, are hotter than ever.
KENWOOD KAC-9102D 1700 WATT MONOBLOCK
This power-house 1,700 watt max output mono-block class "D" amplifier will blow you away. This amp carries 850 watts of pure RMS power, and can compete with the best amps in the business.
Features:
1,700 watts max output Mono amplifier
850 watts RMS @ 2 ohms
2 Ohm stable
500 watts RMS @ 4 ohms
Efficient Class D Circuitry
MOSFET Power Supply
Noise Suppression Filter
Copper Power Transformer
Dual Secondary Caps
Detachable Top Panel for Controls
Die-Cast Alluminum Heat Sink
Advanced Low Pass Crossover
18 dB / Octave Subsonic Filter
Preamp Outputs
High and Low Level Inputs
Screw-Type Power and Speaker Terminals
0-18 dB Bass Boost @ 90 Hz
Single-Side Terminal Placement for a more efficient install
Frequency Response: 5-200 Hz
Signal to Noise Ratio: 100 dB
180.00obo
specs
Features:
2 Ohm stable
MOSFET Power Supply
Dual Secondary Caps
Preamp Outputs
