KAC-6201
2 channel amp for speakers
60 watts RMS x 2 at 4 ohms
75 watts RMS x 2 at 2 ohms
150 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
MOSFET power supply
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
high-pass (150 Hz)/low-pass (80 Hz) crossovers, 12 dB/octave
9-7/8"W x 2-3/8"H x 9-13/16"D
$65 shipped to CONUS
KAC-6201 Features
---------- Post added at 07:29 PM ---------- Previous post was at 07:29 PM ----------
tested, works great. PM if interested.
KAC-6201
MOSFET power supply
KAC-6201 Features
Features
Ground Isolation Circuit: This circuit cancels noise from the input of the negative side of the RCA cable, preventing vehicle electrical noise from interfering with the music.
Quiet Turn-on: This feature allows the amplifier to power up over a period of several milliseconds instead of instantaneously, protecting your speakers from thumps and other sounds that could be damaging.
Internal Crossover: The internal crossover can be set for full-range, low-pass or high-pass operation. The low-pass frequency is fixed at 80Hz with a 12dB/octave slope. The high-pass frequency is fixed at 150Hz with a 12dB/octave slope.
Protection Circuitry: To keep the amplifier safely operating, the protection circuitry is triggered in the following situations:
When a speaker wire may be short-circuited
When a speaker output contacts ground
When the unit malfunctions and a DC signal is sent to the speaker output
When the internal temperature is too high for the unit to operate
When the head unit, or this unit, is not properly grounded
Inputs and Outputs Notes
Left Side of Amplifier:
Battery, Remote Turn-on and Ground Connections: gold-plated screw terminals; each terminal is 0.345" wide
Speakers Outputs: gold-plated screw terminals; each terminal is 0.345" wide
Right Side of Amplifier:
Speaker-level Inputs: screw terminals; each terminal is 0.257" wide
