Kenwood eXcelon KFC-XW10dB 10" subs
Details:
• frequency response 25-600 Hz
• power range 50-200 watts RMS
• peak power handling 800 watts
• sensitivity 92 dB
• top-mount depth 5-1/2"
• sealed box volume: 0.8 cubic feet (from 0.6 to 1.25 acceptable)
• ported box volume: 1.0 cubic feet (from 0.75 to 1.5 acceptable)
Impedance: 4 ohms
Cone Material: PBO Advanced Fiber
Surround Material: Rubber
Ideal Sealed Box Volume (cubic feet): 0.8
Ideal Ported Box Volume (cubic feet): 1
Port diameter (inches): 3
Port length (inches): 7
Free-Air : No
Dual Voice Coil: No
Sensitivity: 92 dB at 1 watt
Frequency Response: 25 - 600 Hz
RMS Power Range (Watts): 50-200
Peak Power Handling (Watts): 800
Top Mount Depth (inches): 5 1/2
Bottom Mount Depth (inches): 6 3/16
Cutout Diameter or Length (inches): 9 1/16
Vas (liters): 79
Fs (Hz): 24.4
Qts: 0.431
Xmax (millimeters): 12
$65 each shipped to CONUS
Both subwoofers and enclosure available for $110 if purchased and picked up locally.
Been stored in the enclosure with grills for several years. Hence the dust on one side. This is how they were stored:
---------- Post added at 07:54 PM ---------- Previous post was at 07:53 PM ----------
Tested, both work great. PM if interested.
Details:
• sensitivity 92 dB
Impedance: 4 ohms
Free-Air : No
Dual Voice Coil: No
Vas (liters): 79
Fs (Hz): 24.4
Qts: 0.431
Say "wow!" to one of the best-sounding subwoofers on the market. Designed for small vented or sealed boxes, and with a cone made from material that's lighter and stronger than carbon fiber, the Kenwood eXcelon KFC-XW10dB 10" subwoofer is efficient enough to deliver low-frequency thunder you can actually feel. In fact, this bass-blasting brute will take just about any high-wattage punishment your amplifier cares to dish out, and love it!
A rigid new cone material, PBO, gives this beast higher potential sound pressure and faster cone response. The rubber surround and gasket are one-piece construction for improved clarity. The 15 mm bumped yoke is up to three times deeper than on other subwoofers, for extra-long cone excursion.
