I have a kenwood excelon amp up for sale. It is stable to 4, 2, and 1ohm mono. Great amp with tons of xover and bass boost features.
It is a refurbished model, and when i hooked the power up the first time, it sparked and a little smoke came out from underneath the amp. That worried me, but when i plugged it in it worked, and no fuses were blown. I have it hooked up to an SS-RLP 12, and it sounds good. Sometimes i wonder if it isn't working to full potential, then i change the song and my rearview rattles. I can't guarantee it puts out full power, but i remember talking to a guy who was an electrical engineering tech and amp repairman, and he said if an amp worked at all, it should be full potential. Anyway, i just got an mtx 500d, so with these couple of issues, i will sell cheap. I guarantee not DOA, and i have tons of references , and my ebay feedback is brian_davis16, with 79 positive and no negative.
Here are pics of it working:
it has the cover, but the seller didn't include the screws. should be easy to find.
here is a pic of the back of the board:
Looking for $100 shipped priority mail. Any less than that i might just keep it or sell to a friend.
specs:
mono car subwoofer amplifier
» 533 watts RMS x 1 at 4 ohms (919 watts RMS x 1 at 2 ohms)
» 1-ohm stable (over 1,000 watts RMS x 1 at 1 ohm)
» variable low-pass filter (50-200 Hz, 24 dB per octave)
» variable band reject filter (40-200 Hz, 0ff/-6 dB/-12 dB)
» variable bass control (-15 to +15 dB selectable for 60/80/100/200 Hz with selectable Q factor)
» subsonic filter (0/15/25 Hz, 24 dB/octave)
» A.M.S. (Amplifier Management System)for control of amp functions from compatible Kenwood receiver
» AMP Information Display (voltage, current, temperature, cooling fan speed)
» Class D design
» 2-speed cooling fan
» gold-plated preamp inputs and outputs
» CEA-2006 compliant
» fuse rating: 30A x 2
» 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 15-3/16"W x 2-7/16"H x 10-3/8"D
specs:
» Class D design
