Kenwood DDX394 losing power!!!
  • 1
Andretti785
I have a Kenwood DDX394 installed in a 2005 impala itworks fine but I dont think it is getting enough power as cuts off depending on how long I've been driving or depending on how loud I have the volume I have the memory/ power wire going to the RAP relay fuse now I broke the fuse prong on the end of the wire so I had to loop it around the fuse prong is it possible getting a new prong for the power/ memory wire will solve the problem or is the relay fuse voltage not high enough or would I have better luck moving it to a fuse with constant power and just manually power the unit on and off ?
191
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
566
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
537
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Andretti785
Andretti785
Topeka, Ks
Andretti785
    Apr 28, 2024
    Apr 28, 2024
