Kenwood DDX-512
well first your going to need a big enough power inverter. DC to AC. Then you deck should have your yellow red and white RCA cables. Then you just plug them in just like your home tv. On your deck then you should be abile to switch it over to aux input
I tried that. I called kenwood and they told me a half assed answer that i might be avle to if I bought a cable and hooked it into the front but I know that wont work. I guess the yellow is only for the rear camera and only that will work. I only have a yellow input to whit or red. I have i think two red, whit, yellow out put and obviously that wont work. I was just wundering if any one els had this issue. I'm also new to the entire car audio thing. I have a lot to learn.
-Jake
CA-C3AV
Audio/Video Input Cable For DNX5120 and DDX512
This is the only cable that will work for your screen. Go buy one from a local dealer. You can't buy this anywhere other then a dealer. It's diffrent then the one from other elctronics chains like radio shck.
heavychevy323
heavychevy323
Gainesville, FL
RXZILLA
