Kenetik Hc1800 vs Odyssey Pc1500
Which one would you pick?
  • Total voters
    12
If its for a replacement battery and not being used as an additional battery I would still get the PC1500. It will hold up to under hood environment much better and the lifespan is going to be much greater. Pretty close in performance... with the extra terminals on the PC you'll probably still be ahead.
when i worked at kinetik they didnt get very many returns on bad product at all. the majority of those warranteed were 600 and 800 sized batteries being used as reserve batteries on systems over 4000 watts which isnt recomended but were warranteed anyway when i say this it was well under 1%. in fact there are 3 to 4 yr old hc power custom banks still taking home trophies.
I didnt intend for my comments to come across as saying the Kinetiks wont work, or do a great job. They will work just fine, it's just that the batt he is comparing to was designed specifically for under hood duty and has obvious attributes that make it a better choice in this application. Both are great batts, and great companies... just trying to answer the mans questions //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
he answered it in the correct way, becuase i do intend to get a smaller pc625 battery from odyssey and put near the load. and with the information you just told me , it would not be idea to place a hc600 there.
i know they both are good, but i needed more help deciding between the two, hell i was just gonna go by weight and call it a day cause specs for the kinetik aren't as clear as odyssey's specs
TwistedMovistar
I'm So Konfuzed
TwistedMovistar
South Memphis, Tennessee
TwistedMovistar
