JL Audio JX 360/2 and Hifonics Brutus BRZ 1200.1D
s3th
Georgia
I DO NOT HAVE THE ORIGINAL BOXES OR MANUALS THAT CAME WITH THESE AMPS
JL Audio JX 360/2 -Have had this baby about 5 months. Wanting to trade possibly, looking for a Precision Power P900.4 maybe this amp and then throw in some cash. If not then just 100$. It's a solid amp with clean power. JL Audio definitely holds up to their name by making, rock solid amplifiers, never got warm or seen barely over 100Watts of Power.
2-Channel Class A/B Full-Range Amplifier, 180 W x 2 @ 2 Ω / 110 W x 2 @ 4 Ω - 14.4V
Cosmetic 8/10 - Minor mounting scratches, a bit dirty but can be cleaned.
Mechanical 10/10 - Never got hot, blasted my Type-R components out of the water.
Hifonics Brutus BRZ1200.1D Me and This amp started with just an Alpine Type-R in a prefabricated box. Moved to a custom box and then 2 HDC3's rated at 1000W Rms. Even it managed to push these beefy subs, and gave me atleast an inch of rear window flex. I'll miss it but I moved on to bigger and better things.
Cosmetic 7/10 - Mounting damage, and scratches, scuffs on casing, tamper sticker is broken on the underside, do to moving the amp around.
Mechanical 9/10 - Hifonics is so underrated it's not even funny. Not once did this amp overheat, or protect on me even over half gain on the subs it's been through.
80$
RMS Power Rating (@ 14.4V):
4 ohms: 450 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
PM me //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
A Link would be very helpful. Id be interested in taking a look at some gear
253
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
366
s3th
s3th
Georgia
s3th
