JL 450.4 v1
glowin3232
Item(s) for Sale: JL 450.4 v1
Item(s) Description/Condition: Item is in like new condition with very minor cosmetic blemishes. The amp was only used for about a month and then I sold the car it was in and I've had it sitting in my closet for a couple years now.
Price: $250 shipped obo
These next 2 pictures are to show the only cosmetic blemished on the aluminum face of the amp, they are very small...
Copied from JL's website, hope this helps...
4-channel car amplifier
150 watts RMS x 2 and 75 watts RMS x 2 at 1.5 to 4 ohms
300 watts RMS x 1 and 150 watts RMS x 1 at 3 to 8 ohms
Regulated, Intelligent Power Supply system
differential-balanced inputs
variable high-, low-, and band-pass filters (high-pass only on ch. 3 and 4)(50-5000 Hz, 12 or 24 dB/octave)
switchable bass boost (ch.1 and 2 only) (6 dB at 48 Hz)
infrasonic filter (ch.1 and 2 only) (24 dB/octave at 30 Hz)
optional wired remote bass boost (ch.1 and 2 only)
Absolute Symmetry™ Class-AB amplifier design
MOSFET power and output stages
speaker- and preamp-level inputs (speaker-level input requires an optional adapter)
preamp outputs
4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier
no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
19-11/16"W x 2-5/16"H x 10-1/16"D
power subwoofers from channels 1 and 2, which have bass boost and low-pass filters available, and drive your front speakers with channels 3 and 4 in high-pass mode;
drive your front speakers with channels 1 and 2, your rear speakers with channels 3 and 4, and use the preamp outputs to connect a separate amplifier to drive a subwoofer system;
power your midbass speakers with channels 1 and 2, and your midrange/tweeter combo with channels 3 and 4;
power left, center, and right speaker systems with channels 1 and 2, and channels 3 and 4 bridged.
glowin3232
glowin3232
Orlando, FL
glowin3232
