Channels 1 and 2:
Rated Power (stereo mode): 150W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged mode): 300W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
Channels 3 and 4:
Rated Power (stereo mode): 75W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged mode): 150W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
Peak Power Output 900 watts approx.
Differential-Balanced Input Topology: (2 pairs of inputs)
Channels 1 and 2 Crossover:
Fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
Channels 3 and 4 Crossover:
THD at Rated Power:
S/N Ratio*: >108.5 dB below rated power
Frequency Response: 5 Hz-30 KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch./50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Preamp Output: 2-channel (Pass-through with selectable input sourcing)
Bass EQ: +6 dB (variable boost up to +15 dB with Remote Bass Option)
Infrasonic Filter (Channels 1&2 only): defeatable 24dB/octave at 30 Hz
Speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Fuse Rating: 60A
Dimensions: 13.4"L x 9.25"W x 2.36"H
