J31Rob's Garage Sale 8/12/12
J31Rob
CarTune Netwerk
1. Product:
  • Eclipse EA4100 4 channel
  • ~30 feet of Monster Cable - 16ga
  • Boss Audio 615UA digital media headunit
  • Second Skin Damplifier Pro - BLACK FOIL - 16 sheets
  • Set of '79 Corvette Rally hubcaps
2. Specs:
  • Code:
    EA Series 4-Channel Class AB Car Amplifier
    RMS Power Rating:
    4 ohms: 75 watts x 4 chan.
    Bridged, 4 ohms: 150 watts x 2 chan.
    Max power output: 200 watts x 2 chan.
    MOSFET power supply
    LED power indicators
    Tuned Bass EQ (0-8 dB bass boost)
    The Integrated Amplifier Series offers outstanding sound quality with a distinctive appearance. Audiophile-grade power amplification is featured along with high current MOSFET switching power supplies that combine for dynamic performance with any speaker system
    4/3/2 channel operation
    High current, high-efficiency MOSFET switching power supply delivers significant power when demanded
    Preamp RCA outputs
    “Easy Tune” top-mounted controls for easily adjusting amplifier parameters even after installation
    Sleek, low-profile appearance with laser-cut top plate allows installation virtually anywhere
    Type of Heatsink (example: Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation)
    Variable high-pass filter (30-500 Hz, 18 dB/octave)
    Variable low-pass filter (50-500 Hz, 18 dB/octave)
    Subsonic Filter ( 18 dB at 18 Hz)
    CEA-2006 compliant amplifier
    Frequency response: 20-20000 Hz
    Dimensions: 13-3/8" L x 10-3/16" W x 2-5/16" H
  • 16 gauge speaker wire
  • Code:
    Product Features
    MP3 Compatible Solid State AM/FM Receiver
    USB Port; SD Memory Card Slot; & Front Aux-In
    Wireless Remote Control
    50 Watts x 4 Channel Power
    SD Memory Card Slot
    USB Port & Front Aux-In
  • Code:
    Specification
    6.5 mil  foil -BLACK
    2 mm total thickness (80 mils) +/- 5%
    Adhesive = Viscoelastic butyl rubber - 99.94% solids content
    .6 lbs per square foot +/- 5%
    12" x 20" (1.67 sq ft.)
    High temperature butyl adhesive with increased elastomeric properties
    Higher rubber content - Less filler content = better performance
  • Hubcaps from a 1979 Corvette. No beauty rings. Sorry.
3. Description/Condition:
  • Eclipse EA4100 - 7/10 cosmetic (surface scratches only) - 10/10 mechanically
  • New condition, still on the spool. Just not a full spool.
  • Boss headunit - 7/10 cosmetic (normal wear & tear) - 10/10 mechanically
  • Second Skin Damplifier Pro - 9/10 cosmetic (creases here & there from shipping) - 10/10 mechanically
  • Rally caps - 9/10 cosmetically (no major surface flaws) - 10/10 mechanically (no bends)
4. Price: :
  • Eclipse EA4100 - $120 shipped
  • 30' Monster Cable - $15 shipped
  • Boss headunit - $30 shipped
  • Damplifier Pro - $135 shipped
  • Rally caps - $50 shipped
*ALL PRICES ARE SHIPPED CONUS.
5. Pictures:
J31Rob
CarTune Netwerk
J31Rob
Indiana
J31Rob
