Iwearpro's Audi A4 build. (ddz,Sundowns.....)
iwearpro
Ok first off,This car is a show car that will not be a spl only car but a show car in general. The items that I chose for this build was bought by me as my choice and no one elses..Now I wish I would have taken more pics of the build but I kinda got involved in the build and let the pics slip my mind..
Ill start with a pic of the car and some of the pieces involved but Ill make sure Ill get more as the build continues and make sure to get pics of the numbers and vids after I get the Term put on it...
Ok here is a small breakdown of parts used.
3 layers of Dynamat,1 layer of spray deadener,foam filled all cross bracing
Alpine IDA-X300 Headunit
Audiocontrol Epic-160
Ma Audio MA15EQ 15 Band EQ
DD 95Z10 platinum coned with twin 1ohm coils
Sundown SAZ-3000 X2 Daisy chained at 2 ohm
Sundown SAZ-100.2
Infinity Kapa Components in all 4 doors
Dc power HO alt 135 at idle 265 at 2k rpms
4 runs of 0 gauge
Kinetik KR5112 1400 x1
Kinetik KR3112 2250 x3
The car
The beast
The Alt
Two layers of birch
Back window slot
Sundown amp rack in place of the rear lower seat before suede
We ran into a issue with the Aeros that we needed to add about 2 inches of length to bring them off the bottom of the box so we built this port extension to sit on top of the rear speaker deck.
Now these pieces were layed into place for a mock up but are not attached so if there are imperfections its because they were sitting in place and the lower amp rack has not been cut for the amps yet..
Couple other random pics
The other pieces ar located in the trunk section and Ill get pics of those later and post them Asd taken.
A4 quattro is one of the most sophisticated awd systems in the world...Full billet coilovers, big brembo brakes....you don't need a ton of power in auto, just good handling..
iwearpro
iwearpro
Forsyth Il
CobraStang98
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
