Ive looked and looked. Visonik?
MattSWE
I need a amp that can do around 800watts at 2ohm @12volts
Visonik rates their stuff at 14Volts but im not sure.
Would this work for (1) L712 ported at 38Hz?
Visonik V317SX
Features:
Variable Bass Boost 0 - 18dB@ 45 Hz
Power/Protection LED
RCA Line Inputs & Outputs
Thermal/Short/Overload Protection Circuitry
Variable HPF/LPF Crossover
Adjustable Input Sensitivity
Full MOSFET Circuitry
60dB Channel Separation
22K Ohm Input Impedance
200mV - 4V Input Sensitivity
Frequency Response: 20Hz - 20kHz
THD
800 Watt Mono
Amplifier
1 x 400W Rms @ 4§Ù
1 x 800W Rms @ 2§Ù
Dimensions (H x W x L): 2" x 9.6" x 11.9"
If not, would you guys please be so kind to reccomend one?
Thank You Very Much.
better off with a lanzar 1200d. best bang for the buck and quality of watts...... visonik amps are nothing fancy. Lanzar class D amps accuallyput out as rated and perform as wel or batter than amps a lil more exspensive than them. hell they do circles around audiobahn amps but any fool could tell you that lol. Besides if u can get an L7 that's dual 2 ohm then u can run it at one ohm but for 2 ohm the lanzar will do a good job.
Maybe the older Optidrives, yes...the newer Vibes are nothing really to write home about. Visionik makes decent products for really affordable prices, and there are a few people on here that have had good luck with them.
so you can take a 2 channel amp, and wire it to 4 ohm and the amp will put 320 by 2 or 640watts to the sub? Can you do that with any amp? Wire it to the ohm specified and its put the double the power to one sub?
no, am am debating on weather to get (1) L712 or (1) L715, $220 shipped for a 2002 Silver cone L715
the 12 would be in a 2.5 cuft box tuned to 38hz and the 15 would be in 4.5 cuft tuned to
35hz.
The lanzar vibe 1200D would be my pick. Im just unsure
MattSWE
MattSWE
E-ville
MattSWE
