is this the way to do this?
mm0142
CEO
is this the correct way to wire to 2 daul 4 ohm subs to 1 ohm i was told to do it this way with no splitter just putting the 3 peices of wire into the terminals .its hard as hell to get all the wire in there . just want to make sure this isnt way my subs both blew in less than 60seconds of ever having power to them
i have the diagrams from 12volt and rockford i just didnt know if you are supposed to stick all 3 wires in the + and _ on the first subs terminals or if im suppossed to use a t splitter to keep it at 2 wires per terminal like the rockford and 12volt diagrams show.. the reason i ask it because i hooked them up to my sundown 1200d 2 12" re se and they blew inless than 60 seconds with the gain all the way down . i think wit was just a problem with the amp but wanted to make sure re says they wont fix them under warranty anyway .
? anyone the diagrams show a t splitter to prevent having 3 wires into oneterminal is this the way to do this correctly ? or can i jsut put all three wires into one terminal
mm0142
CEO
mm0142
Waco, Tx
edzy
