Is this possible?
kinglbj7385
well i need some help guys. I want to just do a single sealed 15 in my trunk but he only problem is that the max height in my trunk is 13".
I wanna do a wedge enclosure but im not sure if it will work because the mounting depth of the sub i want is like 8". can anyone draw me up something quick? max dimensions would be W-38 H-13 D-28.
http://www.the12volt.com/caraudio/boxcalcs.asp#wed
There are two diff types on there and i thought the second one would work better for what im trying to do but any way you can get it to work is good with me. i could draw something up but i cant figure out if the mounting depth of the sub will screw it up. thanks guys
Oh yea i want it to be about 2.6-2.7 before sub displacement so about 2.5 with the sub in
accually i was bored and i looked up that sub and no it is possible
for that sub you need @least 16" of vertical (or near vertical)face to achieve that with you max height of 13 " you must go to 54 ish degrees and @ that angle the sub is to big
the mounting depth is 8"
and hole dia is 14"
disreguard how far back the box goes i just made it big the angled part is the important part
kinglbj7385
kinglbj7385
Cleveland
dappa5
