is this dangerous???
Evan3m
is it possible to run a 4 channel kicker 650 kx amp at different ohms? meaning to have a pair of 6.5'' on two channels running at 4 ohms and then run two small subs at 2 ohm on the other two channels to get more power? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
or would i have to run both the mids and the subs at 4 ohms? i was thinking of two small 10'' rockfords or something like that...any ideas?
(by doing this i am trying to aviod buying another amp)
kicker 650.4 kx
she does 125 rms x 4 at 4 ohms
not sure how much at 2 ohm but it should be more
just want to know if this will hurt the amp
sweet
does any1 know how much power i will get?
if i get 125 rms at 4 ohm on the mids and i put two 2 ohm subs on there how much power will i be getting?
need to know to look for subs
How is it, that the KX650.4 puts out more than the KX800.4, and the 650 cost less than half the price of the KX800. Did I miss something.!!//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
kicker 650.4 kxshe does 125 rms x 4 at 4 ohms
I looked up the specs on this amp:
@ 14.4v
120x4 @ 4 ohms
170x4 @ 2 ohms
325x2 @ 4 ohms
Looks like you should run two of the channels for your comps and bridge the rear @ 4 ohms for 325wrms.
Evan3m
Evan3m
SXM
ultimate157
