ruffryda430
it recommends 0 guage but the people i know at the local car audio shop recommended i jsut use 4 guage.
I agree on that. I was just saying if he already has it and wants to run it for awhile because of the added expense than it could be done. Not the best though.Are you running an amp for mids and highs as well?..or do you plan to? If so, I would run 1/0 from the battery to the distro block, then you can run the 4ga to the Kicker, and whatever size is required for the other amp.Even if that is the only amp, I would still recommend using at least a 2 ga, unless you have an extra battery in the back, and it's a very short run. Here is a recommended power wire size chart:
http://www.the12volt.com/info/recwirsz.asp
so running a 1/0 only from the battery to the d-block and the 4awg output would be ok since i will be running an amp for my speakers?
