SadbutTrue
(cliffnote version at bottom)
Okay, so I've spent all day reading sounddeadenershowdown.com (and browsing it, second skin, and fatmat to compare prices).
I was initially going to get just a roll of Fat Mat and call it a day, but after my research it seems that the Fat Mat is a so-called 'damper' material (similar to the 'Damplifier' product on Second Skin and CLD tiles from sounddeadenershowdown.com, among others). These sites say that covering more than 25% of panels with these damping material yields diminishing results.
I was told by a guy that does classic mustang restomods (and hence installs a lot of systems in these cars) that ~100 sq. ft. is sufficient for the entire car.
Correct me if I'm wrong, but the above information has led me to believe that A) 100 sq. ft. of Fat Mat may be excessive (since 100 sq. ft. is enough to cover the whole car, but more than 25-50' sq feet probably will just be excess weight and not help much with noise reduction) and B) that in order to get the best results, I need to pair it with an vinyl blocker (AKA 'MLV' on most these sites) and possibly a foam (CCF).
Sooo... (I apologize for the book //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )...
I *believe* that it is in my best interest to order ~50 sq. feet. of Fat Mat, and then 65-100 sq feet of an MLV and CCF (each). The best deals I can find on these quantities would be about $80 for the Fat Mat, and $70 for about 67 sq. feet. of MLV and CCF (each, from sounddeadenershowdown.com). This ends up being around $220 plus shipping - on the high end of what I want to spend, but doable. If 50' isn't enough for the Fat Mat, I could get 100 square feet for $130, but i don't want to go over $300 total for insulating materials.
First question: Does all of that sound good and reasonable? Any flaws in the logic? Overkill? Missing anything?
Next...
My Mustang is built with no real barrier between the back of the rear seat and the trunk. Right now, for safety reasons (to prevent a fire from the gas tank from reaching the cabin), there is a sheet of aluminum between the trunk and cabin.
The system I am installing will include at least 1 subwoofer (probably a single 12" since I already have one, but possibly dual 10's instead). There is no room in the cabin for it, so it has to be in the trunk in some capacity.
My original plan was to cut a hole in the aluminum to accomodate my subwoofer's box, put some extra insulation around the box (between it and the aluminum), and then put insulation on the cabin-side of the remaining aluminum sheet - and completely ignore any soundproofing in the trunk itself.
Since the sub would be blasting directly into the rear seat, it would seem that soundproofing the trunk wouldn't really benefit much... plus my Mustang's trunk would more difficult than most modern cars to apply sound deadening too because the surfaces aren't neat and flat. Doing this would also dramatically reduce the amount of insulation needed (not sure if the 100 sq. ft. amount includes the trunk or not).
So... is that a good idea?
Cliffnote version:
1. Would 50 square feet of Fat Mat (serving as a 'damper'), 70 sq. feet of MLV, and 70 sq. feet of CCF be enough to properly deaden/insulate a 1966 Mustang coupe?
2. Can I avoid soundproofing the trunk by placing my sub in the barrier between the trunk and my cabin, and just insulating around the sub and on the barrier itself?
Thanks! //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Next...
Cliffnote version:
