Infinity 4X6 Wont fit...help pls
canadian_mofo
Ok so i got my infinity reference 4X6's today for my 96 sierra reg cab to replace the stock ones i have in the rear. Take out the olds detach them and before soldering i tried putting them in to see how they fit. Well they dont. The magnet is to **** wide and i cant fit it in. What should i do about this? Im new at this but figured this would be the easiest part of replacing the stock system and its already not going well.
well we actually just put those same ones (4 x 6 plates) in my dad's 90' extended cab sierra yesterday.
it just took a bit of trimming around the speaker opening.
trimmed the little lip off on the bottom half of the opening.
if you can get a picture it might help.
are your speakers in the rear © pillar?
~Magick_Man~
its not a matter of pushing them, i think if i did that they would end up getting wrecked. Its also a real pain when the bloody magnet keeps wanting to stick to the side.
yeh if it was a matter of cutting some of the interior plastic thats not problem but the hole where the 4X6 go are a cut out in the actual frame of the truck. So i dunno how i would go about squeezing them into there. May end up taking it to a installation shop.
we just used i jigsaw
if you use a jigsaw or whatever you use make sure the blade isnt long enough to reach the outer skin on the truck //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it was pretty easy and took about 2 minutes to cut both of them.
and yeah the magnet is kind of a biotch //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what exactly is hitting, the basket or the actual magnet?
~Magick_Man~
well there are different jigsaw blades for cutting different materials (wood, metal, etc...)
i would use a metal blade but a sharp wood blade can work just wont be alot of fun to use. and the wood ones seem to usually be longer which might be long enough to hit the outer skin.
~Magick_Man~
canadian_mofo
canadian_mofo
van-city
~Magick_Man~
