Sold Infiniti Kappa Perfect 6.1 Comps, ID XS64 Comps minus Mids, EQS746 7 Band Clarion EQ,
jdubbau
Rating: 66.7%
4 2 0
Infiniti Kappa Perfect 6.1 Component Set
6.5" Mids, X-Over's, and 1" Tweeters
8/10 Cosmetic and 10/10 Mechanical
SPECIFICATIONS
General
Power Handling, RMS 100 Watts
Power Handling, Peak 400 Watts
Frequency Response (±3dB) 75Hz - 23kHz
Sensitivity 90dB
Impedance 4 Ohms
Crossover Frequency(ies) 3.5kHz, 24dB/oct
Mounting Depth 2-3/4" Perfect Mid-woofer, 1" Perfect tweeter
LOWERED PRICE
$135 Shipped
Planet Audio HVT752 Hybrid Tube Amp
ZED Designed and Made incredible sounding tube amplifier
2x50wrms 4ohm and can be ran down to 1ohm
7-7.5 Cosmetic and 10/10 Mechanical
Great Component set or Match for Tru Bass subs and Box I have available.
LOWERED
$179 shipped Con US
Image Dynamics CX64 COMPONENT Set (MINUS MIDS)
Tweets and Crossovers only
Frequency response (hz)
Voice coil (Single or dual)
Voice coil imp (ohms)
Voice coil Dia (inches/mm)
Recommended Power Range (watts)
Mounting Dia Tweeter(inches/mm)
Mounting Depth Tweeter(inches/mm)
Mounting Dia Midbass(inches/mm)
Mounting Depth Midbass(inches/mm)
50 to 22000
Single
4
1.45"/36.8mm
5 to 175 RMS
1.97"/50 mm
.83"/21 mm
5.55"/141 mm
3"/76.2 mm
8/10 Cosmetic 10/10 Mech
LOWERED!
$140 Shipped Con Us
Clarion EQS746 7 Band EQ
Great EQ with cool easy to use features
7/10 Cosmetic (only because top has sticky velcro left from install that you wont be able to see when installed) 10/10 Mechanical
7-Band Rotary Equalizer
12 dB Boost/Cut at 50 Hz, 125 Hz, 345 Hz, 750 Hz, 2.2 KHz, 6 KHz, and 16 kHz
Auxiliary Input with Source Select Switch
Adjustable Aux Input Sensitivity
Subwoofer Output Level Control
Gold-Plated Preamp Inputs and Outputs
Rotary Volume Control and Fader
6-Channel RCA Outputs
Selectable 60/90 Hz Low-Pass Crossover
Crossover Slope: 12 dB/octave
Maximum Output Level: 7V RMS
Input Sensitivity: 50mV–4V RMS
Signal-To-Noise Ratio (S/N): 105 dB
Frequency Response: 10-50,000 Hz
Total Harmonic Distortion (THD): 0.005 %
Input Impedance: 10K Ohms
Output Impedance: 50K Ohms
Stereo Separation: 82 dB @ 1 kHz
Dimensions: 7" W x 1" H x 4" D
LOWERED
$40 shipped Con US
I had these in a friends jeep that did great besides the mids that started to rub. He only had them installed for 3-4 months tops. The tweeters are in great shape and sound very well. If someone doesn't buy em I may just use them in my truck. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
jdubbau
jdubbau
evansville In
Horsemanwill
