DoobieBrother
I've gotten my new components and am considering a couple of things: placement and wiring decision.
1 - Tweeter location. I'll experiment with it to see what sounds best, but I'd like you guys to take a look at the pics I've posted a link to and tell me what you think. The two locations I'm contemplating are - stock position in the doors next to the mids...or in the pillars around eye level. The thing about the pillars is their shape. Note in the pics that it angle in to the glass. Basically, I'd be using pretty much a reflected image from the glass. These are Focal 165V2's, so I can adjust the crossover they come with if necessary. Which brings me to my next question.
2 - wiring. I have a choice, I guess, and being a newb, I'm not sure what is best. I am kind of a set it and forget it guy. Once I get it all dialed in, I probably won't tweak much. Here's the thing. I have an 880PRS, so I can run active, assuming that works in 2 way like it does in 3 way. I'm going to run a JBL 755.6ii amp, so it's give me either 160 x 2 if I use the crossovers, or 60 x 4 if I run active and adjust it all at the head unit. Thoughts on what would be best route?
http://s48.photobucket.com/albums/f240/diungerich/GMCinterior/?sc=1&addtype=local
Thanks in advance for the suggestions. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ETA - BTW, I'll be angling the mids up with angled mdf rings most likely, and can angle the tweeters a bit with their hardware too.
