Image dynamics ID!10v3d4 2 new 2 used
gentlejax
Item(s) for Sale:2 new in box idq10v3d4 and 2 used (1 has bad coil)
Dynamic Impact with the IDQ
The IDQ subwoofer series from Image Dynamics offers detailed and articulate accuracy at extreme volume levels. The ability to offer a dynamic impact without increasing the frequency extension makes them perfect for smaller enclosure sizes. IDQ series subwoofers are available in a 10" and 12" size and in a Dual 2 ohm or Dual 4 ohm version. With the ability to handle from 500 watts RMS to 750 watts RMS, makes these subwoofers perfect for the serious car audio enthusiast. Equipped with a mica-reinforced polypropylene wooofer cone and parabolic roll surround for durability and performance. The removable cone assembly allows for quick and easy servicing of the subwoofer whenever needed. The ability to custom match the basket color to your personal preference sets these woofers apart from any other, while adding a sense of self expression. So if you are looking for some bass that will really bump then the IDQ seirs by Image Dynamics is the way to go.
10" Dual 4 ohm IDQ V.3 Series Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Recommended Power Range: 50-500 watts
Mica-reinforced polypropylene cone woofer
Parabolic roll surround
Removable core assembly for easy and quick replacement
Ability to custom match the basket color to your personal installation
Conex spider with integrated tinsel leads
Fiberglass composite basket
High-temperature aluminum voice coil
Proprietary voice coil attachment design
Also found as: IDQ10D4 V.3, IDQ10 D4 V.3, IDQ10 D4, IDQ10D4, IDQ10V.3 D4, IDQv3
Sensitivity: 85dB
Mounting depth: 5-3/4"
Cutout dimensions: 9-5/8"
new ones $165 shipped 1 used good one $135 i needs repair $100 ?
Shipping and Miscellaneous Item Information:free
There are 4 subs total.
two new subs were still in the shipping box and never opened till me. have not been powered. the used ones had about 6 months use. I tested both. one reads fine (3.9ohms) the other reads good on one side and nothing on the other.
I intend to keep at least 1 working sub so once I sell a couple I may close this. Make an offer if you wish via pm
used one with bad coil $55 shipped
used one good $130 shipped
new one(s) $150 shipped
Subwoofer Specifications
Subwoofer Series IDQ V.3
Subwoofer Size 10"
Peak power Handling 1000 watts
RMS power Handling 500 watts
Voice Coil(s) Dual
Impedance (Per Voice Coil) 4 ohms
Sensitivity 85 dB
Xmax (millimeters) 17 mm
Subwoofer Design Round / Circle
Main Cone Color Black
Woofer Composition Mica Injected Polypropylene (MIPP)
Woofer Surround Parabolic Roll
Subwoofer Grille No
Re-Cone Kit Available No
Recommended Enclosure Specifications
Recommended Enclosure Type Ported / Vented
Sealed
Minimum Sealed Box Volume 0.55 cubic feet
Maximum Sealed Box Volume 1.10 cubic feet
Minimum Ported Box Volume 1.0 cubic feet
Maximum Ported Box Volume 1.50 cubic feet
Top-Mount Depth 5-3/4"
Cutout Diameter 9-5/8"
just installed the used one in a generic ported box. Its not tuned exactly right and the box is a tad small but seems to have as much output as my 12 inch Phoenix Gold Ti2 elite 12.
the PG 12 was in a sealed box where the IDQ10 is in a ported box thats not the proper size or tune.
gentlejax
gentlejax
Bossier City, La.
pauli18c
