Hey Kids,
Long time car audio freak looking for some opinions. I have a big cruiser (aka boat, one that floats, not a 78 Lincoln) in which I've over the years been having a lot of fun adding to the stereo. Currently I have (3) JL 300/4 amps running (14) Focal 6.5" Access CA1 speakers and a JL 1000/1 running (2) JL 12W3v3-4 at 4 ohms in a sealed 1.125cu ft per speaker (recommend) enclosure. The enclosure is sitting pretty much out in the open on the rear deck firing forward into what you might call a cabin area (outside, not inside) - it is mostly open space. It sounds really good, but I'm toying with the idea of changing things up. Why? Because I want a bit more bass that you can feel when you are not on the boat. I spend a lot of time at bars/restaurants on the water tied up to docks and anchored out in a cove swimming behind the boat - while it sounds good behind the boat the really low deep bass doesn't seem to travel very well. So I'm considering Option 1 - Build a ported enclosure for the 12W3's. Cheap and easy as I do all my own work. Should make a difference, textbook says +3db right? Or Option 2 - go with (2) or (4?) 15W0V3... I probably have space for any of the above so that's not an issue. Just looking for some opinions, thoughts and suggestions. I'm really wondering if (2) 15W0 would sound compared to the 12W3's?
Thanks in advance!
Thanks in advance!
