Tek
On Elemental Design's new sound deadener, it's called Xterminator, its a liquid type stuff...err...let the press release speak for itself.
Ladies and Gents We've got a great new deadening product to release to you. The long awaited replacement for eDead v.2.0 is finally here. The name Xterminator. The product is a liquid based sound deadener which has quite a few advantages over our own, and others, mat products. If your looking for a better alternative to the deadening products currently available to you we urge you to read on. Xterminator is extremely unique. It can be applied via a brush and or a spray gun. Few things why this is a little better than the older stuff. Just a few //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
1. Adhesion. It's well. Second to none. You don't need to mix it with anything. It sticks to anything, and doesn't move. Once it's there it's there. You can scrape it or sand it off but as far as adhesion goes. It's light years better than any matt we've used, or sold at any time in the past.
2. Stink. Another wonderful thing. There is no smell. Literally. There isn't one. It smells like whatever your putting it on. No asphalt, no paint smell. No stink at all. It's not asphalt based.
3. Application ease. Another good thing. No rollers and no heat gun. Ever, for any reason. The liquid is just that, a liquid. It's applied through brushing it on, kind of like painting a panel, or using a spray gun. The application side is A. less strenuous B. less messy C. less time consuming than the matt. Another thing about the application. Obviously mat is limited where it can go, or will go for that matter. Liquid can get into anything, anywhere, very easily. It just simply can go places mat can't. eDead included. It's a huge step up in ability to get to nicks and crannies better.
4. Where you can put it. Another beautiful thing. This stuff can go anywhere. The same stuff you spray, paint down in your car and on panels, you can put under your car. In your wheel wells, instead of spray on mastic (etc, etc, we've all used something). So you can pretty much use it everywhere. The color is very boring grey. It doesn't stick out like a sore thumb like the blue samples we've been using
5. It actually also contains a inhibitor that protects against rust. Places where you lay down the liquid it actually protects the car against rust. To boot it's self extinguishing when it comes to fire. Hold a blow torch on it, and it'll burn a little but the second you remove the flame it extinguishes itself. So in reality it helps the car not just the deadening part of it too. That's my spiel.
There isn't a whole lot of information on the web site yet. It'll be coming soon. This is just a addition we've been waiting to make for some time I'm pretty excited about. No more BS deadening. Just the best deadening we could find in existence Main things imo I like. Can be used anywhere inside and out. Doesn't stink. Extremely easy to apply. Don't cut my hands on the back of the mat. Once it's painted on it never goes anywhere. It protects against rust and corrosion and the substance is extremely durable. It does NOT corrode over time. You put it on once, it doesn't flake, it doesn't fall off, it doesn't corrode. Did I mention it's waterproof to boot....
We used Xterminator deadening products in our companies Demo Vehicle for good reason. The advantages aren't just in application, it's in performance. Xterminator can go anywhere, and not come off. We love it.
