Northeast Region IASCA event April 9th @ Oswego, NY
CT,DC,DE,MA,MD,NH,NJ,NY,PA,RI,VT,WV
ok well here are my options...
the 4HP sealed and 3K watts, still with stock electrical, or one of the 12" MT's and 3K watts.....im guessing id be better off with a single 12 since it would put me in stock 1 correct?...now how hard is it to hook up and extra battery in the back?..ive got a couple interstate workaholics i could use but i dont want to put them in there if it isnt worth it.
1-12" with 3000wrms would be better ported than 3000wrms sealed, only can use one extra batt for stock class
but if i hooked up a single workaholic would it benefit me at all??...also what is involved with hooking up an extra battery?
wouldnt hurt. parrallel the wires make sure you fuse them though before the 2nd batt and after. plus the batt has to be secured to the vehicle
so the power wire from the battery to the trunk goes to the positive battery terminal on the extra battery?..mind getting a bit more into detail for me?
While we have two splers in here...can you answer a noob ? for me real quick? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
In db drag...say I have 1 run of 1/0 for power and ground then that go into a distros and 2 4ga power out as well as 2 4ga ground. Would that be 4 conducters or 2?
I would assume its 2 because I dunno how else I would hook up two amps //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. Looking to mess around with street A just a bit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
run a pos wire to a fuse before 2nd battery put another fuse after battery to amps ground 1 wire form second batt to ground
yeah...im confused but ill figure it out....is it possible you have some MS paint skills?//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
SPL140.2
Team DefJ
SPL140.2
NY
SPL140.2
