I would like to brag...
DOHCrazy
I just cut a fresh sheet of MDF.
I need 4 15" wide cuts, and 2 18" wide cuts. I plotted it out on Sheet Cutting Suite, and it looked as if I wouldnt be able to get the last 18" cut out of it. All of these cuts were horizontal in portrait veiw of the sheet, if you understnad what I mean.
I cut the 4 15's, and then one of the 18". To my eye it looked as if the last peice would be too narrow, so I put it against the guide, and it snuggly fit against the blade. I then called myself a pimp, and tested it against the other 18" wide board...
It was a perfect fit.
My day has been perfect.
//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif//content.invisioncic.com/y282845/emoticons/2thumbs.gif.fdc3ba010dbb42b61704534b46d02fe4.gif word DOH is that my box ??? //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
not really you just need to be careful when you do it
dude, jig-saws are made for cutting curves...not a 4x8' piece of mdf...
yes, im sure it can be done...but i would call anyone who did a retard..being your telling me "you just need to be careful"...im calling you a retard...lol
You bet it is... I wanted to get it cut so I could start bright and early in the morning. It takes two people to cut the 4 x 8 down.
Using a mid sized table saw.
Lowes or Home Depot? They **** at making straight cuts, and unless you know someone or frequent there enough that they know you, they usually charge for cuts. In the end its cheaper to buy a small to midsized table saw.
DOHCrazy
DOHCrazy
Dallas, TX
DOHCrazy
