Corsica
I would like to try them as a daily driver though. Too ****ing expensive just for an experament.
J
J
older trucks/cars used to have a tag bolted on the pumpkin w/ axle serial # and gear ratio. if not take your vin # to a chevy service dept, they should be able to look it up. one "shadetree" way to aprx-mate ur ratio(without removing the cover) is to put your trucks rear end up on stands, block the front wheels, put your ****** in neutral, make a mark on a rear tire(say at 12 oclock) and make a mark on your driveshaft(say at 6o'clock). with someone turning the tire SLOWLY ONE FULL REVOLUTION, u count the number of times the driveshaft turns. 3.5 turns.....3.55:1 rears, 3.75 turns......3.73:1 rears, just over 4 turns(say mark stops at 8o'clock)......4.11:1. more than likely it's one of those three, if it's a 2wd truck, my money is on either 3.55 or 3.73. hope that helps some.Originally posted by rsflores steve im lookin to find out what rear end gears are in my truck i cant find the answer anywhere
97 chevy 1500 5.7 extended cab step side
