Lil Poot
you sturrin at me brah?
i just bought a crossfire vr-2000d that was apparently modded to handle high voltages and .5 ohm loads. well, today i hooked it up just to see if it worked, and to my dismay, it wasnt as loud turned up 2/3 of the way as my nine.1 was at 2/3. this amp should do more than twice the power of the nine.1 so im a little confused.
it does play, bass sounds fine, its just not loud. i have both power supplies hooked up, a 1/0 gauge from my battery going back to a dist. block into 2 4 gauge wires, and just 2 4 gauges at the back grounding the power supplies. my electrical system is very solid, and both power supplies are getting 14.5 volts. the remote wires are both getting about 13.2 volts. i have just one remote wire from the deck back to the amp split into 2 now, havent gotten the relay yet, i was just testing out the amp to make sure it worked. the speakers are wired up to give a 1 ohm load, and they are plugged into the correct speaker terminals for mono operation, so it should be giving me like 2800x1, but i'd guess its doing about 800-900x1.
is there anything else i can do to troubleshoot this thing? is it possible only one power supply is functional, and the amp still works but with only half the power?
