I screwed up....uh-ohz
I know this worked for me with running wires in my boat, perhaps it will work for you. Just duct tape a piece of string to the center channel wire, and pull the wire back out of its hole, so essentially all you have is a piece of string run from your receiver to the spot for the center channel. Now, duct tape two speaker wires to the string, and pull the string back through the wall.
Now you should have both wires run to the center channel. You may need to rub some petroleum jelly on it to lube it up a bit if it has a tendency to get snagged on anything.
This //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
To agree with some of the previous posts, it sounds like you CAN bi-amp your center. You, however, don't need to. Typically, I'm bi-amping mine. But, I'm a mad man.
If you do have to run a wire, fish tape works great. BUT, even easier if there is already a wire there and it is a semi straight shot in the wall. Just tape (hook, attach, etc etc) the new wire(s) onto the old wire pull gently and have someone feed as well. Oh, and keep your fingers crossed.
Quoted for Truth & Emphasis.
wj94
wj94
virginia
jmanpc
