Hypnotic Z1750.1D do rated?
brmcm15
Oh lawdy!
Specs:
1,750 watt mono amplifier
Class "D" fully digital power supply
1 x 1,750 watts @ 1 ohm @14.4 volts
1 x 875 watts @ 2 ohm @14.4 volts
1 x 440 watts @ 4 ohm @14.4 volts
Crossover slope: 12 dB per octave
Bass Boost @ 45 Hz: 18 dB
1 Ohm Stable
Audiophile grade components
High efficiency mosfet design
DC-DC PWM power supply
Bipolar outputs
Very Efficient and Low Current Draw
Subsonic filter: 20Hz - 50Hz
Buffered pre-amp input circuitry
On-board variable precision x-over 12 dB per octave
On-board bass boost
Hypsink technology (Heat management system)
Translucent, blue illuminated Hypnotic logo
Input Sensitivity: 200mV - 5.8V
Input Voltage: 11-14.4 Volts
RCA and Speaker level inputs
Signal to Noise Ratio: 90dB
THD @ Rated Power:
Dimensions: 15-3/4" L x 8-7/8" W x 2-1/8" H
Detailed Specifications:
Frequency Response: 20 Hz - 250 Hz
S/N Ratio: > 90 dB
Low Input Level: 246 mV - 5.9 V
Crossover Frequency: 40 Hz - 250 Hz
Crossover Slope: 18 dB
SubSonic Filter: 20 Hz - 50 Hz
in theory:
14.4v x 60amps = 864watts? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
discuss
*i emailed db drive and asked for some internal shots and some more info, should be getting a reply soon..
i talked to a shop who use to sell them and they told me the amps even get hott on normal loads like 2 and 4 ohms. id say stay clear. but he did say their better woofer wasnt too shabby
well i got an email back.....with no internal shots //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
just a link to the manual lol
brmcm15
Oh lawdy!
brmcm15
Macomb, Michigan
DarkScorpion
