Hydraulic Pumps
Two completely different things.
He's not asking about anything having to do with linear actuators.
Try Reds Hydraulics in FL.
INTERNET wise
i dont want to jump i want to lift in lower and go 3 wheel motion
(THE PURPOSe IS NOT FOR DRIVING ITS FOR SHOW:naughty: )
air ride suspension is like hydraulics.....but without the fluid (air instead) and the batteries.
hydraulic cylinders are replaced by air bags or air struts (or air cylinders, which I hate)
I think you are better off going with air ride, unless you are planning to hop your ride. Another thing is that without accumulators, hydraulics ride crappy.
It is difficult to three wheel with air ride, any decent three wheel anyway. Extending A arms and such. Three wheel makes the frame cry
Extended A arms, huh?
I can three wheel my mustang with NO modifications to the A-arm, and I have never 'extended' an A-arm on anything I have installed air ride on. I HAVE sectioned A Arms, and lowered the mounts, but that was for the vehicle to lay a little lower.
Please only talk about things you know about.
You will need a dual action setup. You will have to have a dual action setup, and it is VERY difficult to get a dual action setup with AIRBAGS. Air cylinders are neat little 3 wheel toys, but not originally designed for automotive use.
I like air ride, but given the choice, I would prefer hydaulics. No compressor whine. No amperage draw from a larger compressor. Play all day without the need to refill a tank. Get higher, and lower (generally).
bcleachd
Banned
bcleachd
columbus ohio
bcleachd
