n2audio
OPTIDRIVEN
Just bought this truck.
I've got two problems -
One, my power antenna doesn't work at all. I even ran a wire straight from the battery and shorted it to the antenna terminal at the wiring harness - got nothing. If it was a fuse I would think there would be other electrical problems, but everything else works.
The other issue - installing the HU. There is one standard plastic wiring connection, but it only houses 5 wires: consant, switched, pwr antenna, dimmer and illumination. Everything else connects through two barrell type connectors. Metra only offers a kit that connects to the 5-wire plug, and another adapter to get signal to a factory amp - which I can't even find.
Any info would help.
If I could just make the antenna work I'd be ok for now. It looks to me like the motor might be shot, and if that's the case - getting it out could be a REAL pain. Anyone happen to have done that on a mitsubishi?
