How to wire batcap 2000?
ghart999
Adding a batcap 2000 as 2nd batt along with red Top as main.
The batcap.net diagrams confuse me.
Can I not ground the batcap to the chassis? I have to go direct to main batt or amp?
I mean how can one fit two 0 gauge ground wires into the amp?
Also what about power? Can't I go from main bat to batcap to amp?
I would think I could just do the following:
Power from main bat to batcap (fused near batcap) to amp (fused again).
For ground, can't I ground the amp and batcap at a common ground point on the chasis?
Thanks a lot.
Can I ground the batcap to my ground distro block or use a separate ground?
Also what is the reason to ground the amp to batcap and not chassis/distro block?
you want the least amount of accessory grounds as possible. An ideal setup would be straight battery to battery ground, but you can get away with a frame/chassis ground if its a darn good ground. The best way for this would be to ground the battery to the frame, and ground anything else to the battery.
ghart999
ghart999
Denver, CO
ghart999
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
