Maybe you have scores of DVDs, or even hundreds. You always want to put them on your portable devices. However, the format of DVD cannot be supported by these devices. This guide will show you how to rip DVD to all video and audio formats for all the portable players. The output formats mainly include: MP4, AVI, MOV, FLV, WMV, MKV, 3GP, 3G2, MPG, MP3, AAC, M4A, OGG, RA, RAM, RMVB, etc.
This article is divided into two parts:
Part 1: How to rip DVD on Mac
Part 2: How to rip DVD on Windows
Part 1: How to rip and edit DVD with a professional Mac DVD Ripper
Step 0: Download and install Tipard DVD Ripper for Mac(Intel Version) or (Power PC Version)
Step 1: Load your DVD
Step 2: Choose the output format and set the exact parameters
Click “Profile” drop down arrow to choose the output format you want.
Click “Settings” to set the exact video and audio parameters to fit for your player.
Step 3: Click “Start” button to begin the conversion
Wait for a short moment, the conversion will be finished soon.
Some other editing functions:
1. Set audio track and subtitles for your converted video
“Audio Track” and “Subtitle” are under the preview window
2. Get any time-length video clips
Click “Trim” button to open the trim window, you can set the exact begin and end time for your clips or just drag the slider bar.
3. Adjust the video play region
Click “Crop” to open the crop window to crop off the black edges around your video or adjust any video play region. You can also set the video play ratio when playing on player: keep original, full screen, 16:9, 4:3.
4. Set the video effect
Click “Effect” to adjust the video Brightness, Contrast, Saturation and Volume for you to get the perfect playing effect.
5. Join several chapters of your DVD into one file
Select the chapters that you want to join, and then pick “Merge into one file”. After conversion, these chapters will be saved into one file.
Part 2:How to rip and edit DVD with a powerful DVD rip software(For Windows)
Step 0: Download and install Tipard DVD Ripper.
Step 1: Click “Load DVD” button to load your DVD.
This professional DVD Ripper can load three DVD source, you can load your DVD from DVD drive, DVD folder in your PC and also IFO file.
Step 2:Select the output video format you want from the “Profile” drop-down list.
Step 3:Click the “Start” button to begin your conversion.
You can have a coffee or have a walk now ! In a short while the conversion will be finished.
Tips:
Some powerful editing functions are available as followings.
1: Capture your favorite picture.
If you like the current image of the video you can use the “Snapshot” opinion. Just click the “Snapshot” button the image will be saved.
2: Merge videos into one file.
Just check the “merge into one file” option if you want to merge the selected contents into one file As default the merged file is named after the first selected file (either a title or a chapter)
3: Trim any clip of your video.
You can get any clip of your video by just using the “Trim” function. You can click the “Trim” button and a dialogue pops up. You can set the Start Time and End Time or just drag the slide bar to the position you want and start conversion then you can get the clip.
4: Crop video
Crop by setting the crop values
There are four crop values on the lower right part of the crop window: Top, Bottom, Left and Right. You can set each value to crop your movie video, and the crop frame will move accordingly.
Note: Before you start to crop your movie video, you can select an output aspect ratio from the Zoom Mode. There are four choices available: Keep Original, Full Screen, 16:9 and 4:3. After you select an output aspect ratio and finish the crop, the result can be previewed in the Preview window of the program main interface.
Mac DVD Ripper
MP4 Video Converter
Tips:
4: Crop video
Mac DVD Ripper
MP4 Video Converter
