Sold How to import MOD files from HD camcorders to iMovie on Mac OS X?
  • Thread starter zsvrsn3
  • Replies 0
  • Views 363
iMovie is a proprietary video editing software application which allows users to edit their own home movies. It imports video footage to the Mac using either the FireWire interface on most MiniDV format digital video cameras, the USB port, or by importing the files from a hard drive. However, the supported formats don’t contain the MOD files from HD camcorders. In other words, MOD files can not directly import to iMovie for editing.
Here I just collect these camcorders which generate videos in the format of MOD.
If you just have one of these above camcorders, the way to import the MOD to iMovie may be what you are urgent to know. Don’t worry. Now with this Mac MOD converter called Moyea MOD Converter for Mac, everything will be Okay. This program is designed to convert MOD to almost any video or audio format with easy to use interface at high conversion speed and excellent output quality.
Are you ready? Just follow me.
Part one: Convert MOD to iMovie with Moyea MOD Converter for Mac
First of all, free download Moyea MOD Converter for Mac here, install and run it.
1) Click “Add” button to import the MOD files into this program. Then you can select the output format as iMovie workable format like MOV from the drop-down list “Format” as well as set the output files location from the “Browse”.
2) Click the “Settings” button on the main interface, a profile window will pop. Under the profile window, you can adjust audio and video parameters for your reference, like codec, bit rate, frame rate, resolution, and the aspect ration and so on. You can also hit the “Save as” to save the setting for next time use.
3) After selecting a video file, you can also click the “Edit” button to do some editing jobs on your video before converting, like trimming, cropping, adding effects and watermarks and so on.
4) Tick the “Merge into one file” to merge or join several MOD files into one.
5) Once all the settings are done, you just need to click the “Convert” button to start video conversion. Although the MOD files are usually big, this Mac MOD converter’s multi-thread encoding techno can compress and convert them in a little time. What’s more, it can prevent any audio and video sync issues for its advanced audio and video synchnization.
Part two: Import the converted video files to iMovie
After the whole video conversion is finished, just click the destination folder you set to get the converted video files.
Now click on the iMovie icon on your Mac to launch iMovie. A window with a little instruction movie about the iMac appear (Figure 4). To the fight of the movie you should see the following options: “New Project”, “Open Project”, and “Quit”. Choose “New Project”. Then you can import the converted files to it: Choose “File” menu -] Import files.
If you don’t know how to use iMovie, just click here http://reach.ucf.edu/~pezone/tech/imovie/
zsvrsn3
Banned
zsvrsn3
3636 Gateway Center, San Diego, Canada
zsvrsn3
