Sold How to convert DRM Protected iTunes M4A to MP3
  • Thread starter windbell
  • Replies 0
  • Views 366
windbell
What is a M4A
.M4A is the audio file compressed with the Apple Lossless Encoder (ALE); uses the Apple Lossless Audio Codec (ALAC), which provides lossless compression; saved in the MPEG-4 container format.
The M4A files are similar to .MP4 video files, but do not contain a video track; MPEG-4 audio files that include copyright protection, such as those sold through the iTunes Store, typically have an .M4P extension.
As M4A music files downloaded or purshase from iTunes has DRM protection, so if you want to play m4a songs on other non-apple players, cell Phone, etc, you may need to convert M4A to MP3 or other unprotected music files, and below is a quick tutorial to convert M4A to MP3
What we need is Daniusoft Digital Music Converter, it's a Music DRM Removal and iTunes M4A to MP3 Converter that can batch convert iTunes M4A to MP3, M4P to MP3, AAC to MP3, WMA to MP3, etc music files with high output quality.
And it's every easy to use, the whole process to convert M4A to MP3 just includes 4 simple steps:)
Step 1.Free Download Daniusoft Digital Music Converter, install and run it.
Step 2. Click "Add" to add M4A files or set up your DRM Finder to import the m4a music files you want to convert Or you can just Drag & Drop your files to main processing windows.
Step 3.Choose output format
Directly click the "Convert to" pull down menu to choose your desired music formats. Or Click "settings" to open the Settings Window, here you also can choose output format and customize music settings.
Step 4.Convert M4A to MP3
After finishing all the necessary steps, you can click "Start" to convert your M4A music files to mp3. When the conversion progress reaches 100%, the DRM copy protection on m4a music is removed and m4a is converted into MP3.
Now you can play your own songs in the way you like.
windbell
windbell
United States
windbell
