HOw to convert AVI, MKV, WMV, MP4, MOV, MPEG, ASF, 3GP to XviD?
informationspy
34
CA
"HOw to convert AVI, MKV, WMV, MP4, MOV, MPEG, ASF, 3GP to XviD?
Hi,guys!I am very glad to come this forum to share with you a very good convert that ishttp://www.xilisoft.com/xvid-converter.html Xilisoft XviD Converter[/url]
This guide is supposed to be used by people who want to convert video formats to XviD video files with Xilisoft XviD Converter. Follow the guide and complete your XviD conversion step by step. First, download, install and run Xilisoft XviD Converter.
Step 1: Load files
Click ""Add File(s)"" button on the toolbar or ""File > Add File(s)"" to load the files you want to convert.
You can also click ""File > Add Folder"" to select the folder you want to add, then all files in the folder will be loaded into the file list.
Step 2: Choose output format and folder
Choose the file, click to open ""Profile"" drop-down list in the ""Target Profile"" column or at the bottom of the main interface, then choose the format you want.
Click ""Browse"" button to choose the destination folder for saving the output files.
Tip1: Click ""Snapshot"" button below the preview window on the right-bottom of the main interface to take a snapshot during preview to save as JPG, GIF, PNG, or BMP file.
Tip 2: You can double click the loaded file in the file list to view the file information.
Step 3: Adjust output settings
1. Add multiple profiles for the same source file
Select the file and click the ""Add Profile"" button to add a default profile to the file, then select the profile you want from the ""Profile"" drop-down list. In this way, you can get them converted in one click.
2. Customize output file size with Bitrate Calculator
To customize the output file size, select the video file and click ""Tools > Bitrate Calculator"", and input the file size you want, then the video bit rate will be calculated. Click ""OK"" button, the size you enter will be displayed in the ""Output Size"" column.
3. Set the output parameters
On the ""Profile Settings"" panel, you can set the following parameters: Name, Video Size, Video Quality, Audio Quality, Channels. Click ""Show Advanced Profile Settings"" button to expand the advanced profile settings page, in which you can set more parameters for satisfying more needs.
Step 4: Convert
After the above settings, click ""Convert"" button on the toolbar to start converting. You can pause, resume or stop the conversion at any time.
After conversion, you can click ""Open"" button on the bottom to view the output files directly.
http://www.xilisoft.com/xvid-converter.html"
informationspy
informationspy
CA
rusty_armadillo
