How is the knukonceptz KCA Kable (PWR wire)
only huge difference in CCA and OFC is CCA has more resistance and you get slightly less power draw (depending on the wire quality) than you would OFC.
Try Audio Technix OFC or CCA much cheaper for great wire.
I've used it before, there's nothing wrong with it, it's some of the best bang for your buck wire you can buy so long as you're not running loads of power (anything more than 200A I would go OFC)
The AT wire is definitely cheaper, but it is also noticeably smaller with about 10% fewer strands that are also about 75% of the diameter of the knu wire.
Sketchup
Sketchup
Iowa
dragnix
